5 comments
Comment from: Dmitry Novikov Visitor
Comment from: Agent Kith Member
ARMv7 edition of Snakeoil is not ready yet. Hopefully I can find some time to implement that in the coming months.
Comment from: jucas_pt Visitor
Hi,
Great article, I just add one thing…you should tell to look for the permissions of the folders where the private keys are. I’ve got some issues when i tried to connect to HTTPs and was resolve by changing the permissions of home assistant user for that folders. Maybe because of the version of hass.io - 0.82.1
Cheers
Comment from: clplarry Visitor
Is the IMG file of Snakeoil ready for Raspberry Pi 3B installation? Is it as easy as volumio or Runeaudio for installation of the Snakeoil just by flashing it onto a micro SD card and inserting it to the Raspberry Pi so simple? Where is the location of all the OS installation files stored on the web? Can I have the relevant link here to search them out and have a trial?
Thanks
Yes, the IMG file works with all versions of Raspberry Pis - mainly because it’s 32 bits.
All the Intel ISOs and IMGs are in one location, follow the "Version" link in this article to get the latest image to use.
It is very interesting that I cam use Pi to install Snakeoil. any special image required?
